3D object scanner
Thanks for suggestions guys,
Forgot to mention that I have tried this using FARO laser arm and hence I am sure this will give the 3D image of that exposed localised parts.
I am planning to order NI board but confused which one to buy
Message 11 of 15
(1,467 Views)
But the FARO arm can move, the MicroTrak cannot.  You still haven't told us how you plan to control the position of the beam in relation to the object.  Something has to move in a position controlled manner to provide spatial info back to the imaging software.  Reading the output of the MicroTrak is easy.   It has a max output of 40KHz and there are many, many DAQs that can do that for one channel.  Your decision is mostly financial there.  If you need to scan a laser beam or move the MicroTrak in a feedback-controlled way, that's when things get more compicated and you'll need to chose a DAQ with better Analog Out (AO) abilities.
LabVIEW Pro Dev & Measurement Studio Pro (VS Pro) 2019
Message 12 of 15
(1,453 Views)
Finance is not the concern.
Also the s/w is just Labview I think for which I have the licence copy.
Message 13 of 15
(1,436 Views)
I would suggest an X-series USB-6351:  http://sine.ni.com/nips/cds/view/p/lang/en/nid/209071
It will be more than enough for your current needs and be useful for future projects as well.
Have you checked out this 3D scanning forum?  There is a lot of information on products similar to what you are doing:  http://www.3dlaserscanning.org
Message 14 of 15
(1,432 Views)
Hey Thank you very much
You have been really kind in replying.
Will start mostly with this board inspite being a lil expensive.
Message 15 of 15
(1,429 Views)
