3D laser scanner save data output
Dear all
I am a newbie in 3D laser Scanner. We have built a 3D laser Scanner system like this link :
https://www.youtube.com/watch?v=qmfwPXYO5vM
At the momnet, we have obtained 3D image of object, and we also have three array of information of this 3D object. However, I do not know how to save these data. We wanna have *.COP file ( cloud of point) to use in 3D Mechine Vision Library ( a product of Imaginglab: http://www.imaginglab.it/eng/3D-MVL_DataSheet.php )
Could you have any suggestions for me?
Thanks!
Message 1 of 9
(5,415 Views)
Sounds like if you sent NI $599, you could simply buy that scanner.
BS
Message 2 of 9
(5,375 Views)
But we need this data to solve our problem
Message 3 of 9
(5,348 Views)
It looks like the library by ImagingLab has all you would need to save files as a .COP file. Have you tried to use that library and are having problems?
Tanner B.
Systems R&D Engineer - Aerospace, Defense, and Government
Message 4 of 9
(5,323 Views)
Dear Mr Tanner,
Thank for you comment
I have checked the ImagingLab's Library, but I still have no way.
Message 5 of 9
(5,294 Views)
Hi Quach,
Are you getting errors? Are you unable to find the correct functionality? Can you run examples?
JD B.
Message 6 of 9
(5,243 Views)
Dear Mr. JD B
I have found in 3D-Machine Vision Library, but I could not have success. I cannot found a way or a function to do that.
Thanks.
Message 7 of 9
(5,156 Views)
Hi Quach,
If you are having problems using the 3D Machine Vision Library, I suggest contacting ImagingLab for support. Since this is a 3rd party add-on they will be more familiar with the product.
JD B.
Message 8 of 9
(5,108 Views)
Another option is to use the .ply format. Have a look at the Haro3D library (download from VIPM). More info at www.harotek.com/products.
Let me know if you have any other question.
p.s.: I invite you to joint the 3D Vision user group.
Marc Dubois
Message 9 of 9
(4,939 Views)
