3D graphical representation
Before I dive into a new piece of code, I would like to ask the advice of some grumpy old men Smiley Wink
I would like to make a 3D intensity plot... I think that is the best way to describe it.
We will have a cube with a matrix of thermocouples throughout various locations.
I've gotten as far as getting all of the temperature values into a single array.
I need some advice from here.
Should I create a 4x4x4 array (if such a thing exists... I have no experience with anything beyond 2D)?
Also, what type of plot/graph/chart would you recommend?
Thanks!
Cory K
(3,388 Views)
Re-reading over my last post, it may not be that clear what I would like to do.
Here is a more thorough explination.
I would like to set up a plot in 3D.
I will have 16 x,y pairs, where the x will be the location of the point in the format
(x,y,z)
and the y will be the temperature.
So on the plot at the location (x,y,z) I would like the color to reflect the magnitude of the temperature
the same way it would on an intensity plot. The only difference would be that this is in 3D.
I hope that cleared up the problem a little bit.
Edit: I should also work on my math haha. It will not be 4x4x4. It will be 2x2x4
Message Edited by Cory K on 03-04-2010 01:39 PM
Cory K
(3,385 Views)
Accepted by topic author Cory_K
Take a look at my 3d car code. It should get you started.
Post back after you have played with it if you still have questions.
Ben
(3,367 Views)
Success! Thanks a lot Ben!
Cory K
(3,357 Views)
