3D array
I have 3D array (4x6x4) with the data. I need to create 1D array with the data at a given row and column for all the pages. I prepared a picture to better explain it. The red arrow goes through the pages 0,1,2,3, and points to the data contained in row 3, and column 0 creating 1D array with 4 elements. I need to “scan” all the rows and columns to create 6x4=24 such 1D arrays. Is there simple solution to this problem? I am running LabVIEW 8.6.
Thanks in advance!
Message 1 of 8
(4,162 Views)
Try this.
CLA CTAChampionI'm attending the GLA Summit!
Subscribe to the Test Automation user group: UK Test Automation Group
Message 2 of 8
(4,147 Views)
Thanks .:aCe:.  it is very close to the solution. The only problem is I need to “scan” through all the rows and columns automatically in a loop.
How can I accomplish this?
Message 3 of 8
(4,131 Views)
Accepted by -Chris-
.:aCe:. is on the right track. (but begging to make the Rube Goldberg threadSmiley Wink) the Resize Array primitave solves for the general case and can reuse the array buffer saving some RAM to bootSmiley Surprised
"Should be" isn't "Is" -Jay
Message 4 of 8
(4,125 Views)
Good one Jeff. I did not read the last lines! Well not properly anyway, thats my excuse!
Whats your excuse of not saving it in version 8.6? Smiley Wink
Message 5 of 8
(4,123 Views)
Thanks Jeff, it works!
Message 6 of 8
(4,111 Views)
Since the "code" needed is a primitive and some wires I assumed the OP had it in 8.6Smiley Very Happy
Message 7 of 8
(4,103 Views)
I think Jeff meant to say "reshape array". It will give you a 2D array that may or may not be exactly what you want, because you specified you want 24 1D arrays. Who knows? 😉
To generically get a single vertical column, you would use "index array" (see image middle, top is equivalent code by ace).
To scan over all vertical columns, you would place it in a stack of 2 FOR loops and iterate over the xy positions.
Message 8 of 8
(4,097 Views)
