3D Scene Background
I have a 3D object using Scene Window and I would like it to be displayed in front of a 2-D planar image as a scene background.  Is there any way to do this, either using an image file or drawing lines within the scene?
Thanks!
(3,862 Views)
alternatively, if anyone knows how to apply texture to a 3D mesh, that would work as well. Thanks!
(3,847 Views)
to use 2D on the 3D environment, you have to create a object in 3D with one of dimensions very small. For example, a Box with height 1E-6 will be a square. After that, apply texture to the box. This will show the object with the image you want.
LabVIEW has a shipping example that shows how to apply texture on spheres.
C:\Program Files\National Instruments\LabVIEW 2009\examples\picture\3D Picture Control\solarsystem.vi
This should do what you are looking for...
Barp - Control, Simulation, RTT and HIL - National Instruments
(3,829 Views)
Can u show how to do like a boat on the water with water as an image as the background?
(3,608 Views)
Hi id,
I think that you are talking about something like this example. I hope this one helps. You can look for more example code at ni.com/code.
Reagards,
steve.bm
AE | NI
(3,591 Views)
