3D Picture Control Using Solid Works VRML File and Moving Individual Components
Hi, i am new to these forums and am looking for help concerning 3d picture control, i am a undergraduate student doing a second year project to control a 4DoF UAV.
I'm trying to sort out the 3d simulation of it, i have made the solid works drawings and assembly then exported that to a single WRL file (in the correct format ie. ver. 97) however when trying to import that to Labview i am having difficulty setting the relationships so different parts rotate etc. in the assembly.
i'll attach the corresponding example vi from labview and my solid work files.
Any help is very much appreciated
Tom
Message 1 of 9
(8,104 Views)
Can't look at your stuff but I have worked with similar.
The issue for me was each of the components in the wrl file must be named for you get get at the parts. The name is the handle used to touch them. So if you get the wrl file right you should be able to get at the components.
Ben
Message 2 of 9
(8,098 Views)
thanks for your reply, i've seen other post saying similar things but assumed that the manes should be inserted automatically when saving the VRML file, i tried opening the file using notepad to enter manually however its quite complex and didn't know where to begin.
Message 3 of 9
(8,094 Views)
I believe I found a definition of wrl files in wikipeadia.
Start there.
I had to hack my file to add the names but it worked.
Ben
Message 4 of 9
(8,092 Views)
i'll have a look
thanks
Message 5 of 9
(8,089 Views)
hi again,
i've tried your suggestion with the naming however, i am using seperate VRML files for the different components and using the main vrml file to control the prent-child relationship etc. however when trying to access that file through labview it can't open it. this is the code within the vrml file
#VRML V2.0 utf8
DEF assembly Transform {
Children [
Inline {
url [" Bottom Base.wrl "]
bboxSize -1.000000 -1.000000 -1.000000
bboxCenter 0.000000 0.000000 0.000000
DEF Revolve Transform {
Children [
Inline {
url [" Top Base.wrl "]
DEF Elevation Transform {
Children [
Inline {
url [" Arm Pivot.wrl "]
DEF Connector Transform {
Children [
Inline {
url [" Rod-Base Connector.wrl "]
DEF Rod Transform {
Children [
Inline {
url [" Rod.wrl "]
DEF Roll Transform {
Children [
Inline {
url [" Mount Connector.wrl "]
DEF Pitch Transform {
Children [
Inline {
url [" Mount Pivot.wrl "]
DEF Mount Transform {
Inline {
url [" Arm Mount.wrl "]
DEF Chassis Transform {
Inline {
url [" Chassis.wrl "]
DEF Gearhead1 Transform {
Inline {
url [" i_gearhead.wrl "]
DEF Gearhead2 Transform {
Inline {
url [" i_gearhead-1.wrl "]
DEF Gearhead3 Transform {
Inline {
url [" i_gearhead-2.wrl "]
DEF Gearhead4 Transform {
Inline {
url [" i_gearhead-3.wrl "]
DEF Shaft1 Transform {
Inline {
url [" i_shaft.wrl "]
DEF Shaft2 Transform {
Inline {
url [" i_shaft-1.wrl "]
Inline {
url [" i_shaft-2.wrl "]
DEF Shaft3 Transform {
Inline {
url [" i_shaft-3.wrl "]
DEF Prop1 Transform {
Inline {
url [" Propeller.wrl "]
DEF Prop2 Transform {
Inline {
url [" Propeller-1.wrl "]
DEF Prop3 Transform {
Inline {
url [" Propeller-2.wrl "]
DEF Prop4 Transform {
Inline {
url [" Propeller-3.wrl "]
DEF Shell Transform {
Inline {
url [" Shell.wrl "]
DEF Dome Transform {
Inline {
url [" Dome.wrl "]
Message 6 of 9
(8,081 Views)
Hey Thomas
I have no experience with VRML but in other coding languages you generally have to pass a reference of the controls in the top level code for other programs to gain access to them. I see you have calls all your models but no syntax as to what to do with them other than dimensions. Again I stress that I have no knowledge of VRML so this is all speculation.
Matthew Trott
National Instruments UK
www.ni.com/ask
Message 7 of 9
(8,070 Views)
I dont know if you have seen these links as well but I thought they may prove helpful.
[broken links removed; articles no longer available]
Matthew Trott
www.ni.com/ask
Message 8 of 9
(8,067 Views)
thanks for everyones help, i think i've managed to sort it now, just need to make a few adjustments
Cheers
Message 9 of 9
(8,060 Views)
