3D Model Integration with LabVIEW
I want to make a simulator for which I have prepared one 3D model with the help of Sketchup software and I want to integrate it with labview.
Means for simulator my fancy front face will be 3D model but all the calculation part will be on labview.
I need your help to make this happen.
Note - I have seen example in labview to call 3D model with help of VRML Code but it is not so good, it degrades the model.
Any help would be helpful how can i integrate 3D model with labview.
Thank you
(2,810 Views)
Degrading how?
The "Using VRML with File.vi" example seems to work fine.
Note that the model and the environment it's in are two different things. The render is yet another thing. So while a 3D modeling tool might have fancy lightning and shaders setup just as you like them, LabVIEW won't.
Any help would be helpful..
By definition, I'd say 😉.
(2,770 Views)
