3D Interpolation Table
Hello!
Does anyone knows how to build a VI that that makes a intepolation from a 3D Table?
(4,395 Views)
If what you have is an array of {X|Y|Z} coordinate bundles, then your task is easy:
If you want a coordinate 1/4 the way between this point and that point, you solve:
This + (That - This ) *0.25
That works without separating the components - it will even work on two whole arrays directly, if that's what you have.
Steve Bird
Culverson Software - Elegant software that is a pleasure to use.
Culverson.com
LinkedIn
Blog for (mostly LabVIEW) programmers: Tips And Tricks
(4,388 Views)
Could you clarify what your definition of a 3D table is?
A table is usually 2D array. Do you want to interpolate in 2D, e.g. get the value at fractional index pairs? In this case, easiest would be to make a bilinear interpolation as e.g. shown in one of my earlier posts .
(4,386 Views)
I use a 3D Table to build a 3D Graph. The idee is to find z point using x and y points. The interpolation is not liniar.
(4,370 Views)
Well, now I'm really confused.
You can't construct a Z point of a 3-D object based on an X and Y point.
Z is an independent axis, not a function of X and Y.
If you ask a better question, you'll get a better answer.
Steve Bird
Culverson.com
LinkedIn
(4,365 Views)
I second Coastal's comments.
Take a good close look at the examples that Altenbach suggested.
As revealed in his bio found here
http://www.ni.com/devzone/lvzone/member_altenbach.htm
" I have completely rewritten the Levenberg marquardt routines to allow global fitting of multiple multidimensional data sets and runtime selection of fitting parameters. "
He does math like this for breakfast.
Ben
(4,357 Views)
