3D Graph Color Bug
Hi Doug,
I can assure that the color bug as described by X in the first message hasn't been fixed yet in LV 2011 SP1.
The color of the frame must be modified in the Facade.vi inside LV installation directory and not in the panel of the specific vi you're working on.
And so if you change the devlopment PC you find a different color for the frame when you open the same source vi.
Vix
In claris non fit interpretatio
Using LV from 7
Using LW/CVI from 6.0
Message 11 of 14
(2,149 Views)
Hey vix,
Thanks for looking into that. The VI that was originally posted by Scott as the solution includes some VIs that are not supported in LV2011 or in LV2011 SP1. I will try and look into the current setup of those particular VIs in LabVIEW 2011 SP1 and see if I can come up with a solution for you.
Doug B
Applications Engineer
Message 12 of 14
(2,139 Views)
Did you manage to find a solution to this?
Message 13 of 14
(2,095 Views)
ckeiderling,
Are you asking if a solution to the VI's not support in LV 2011 has been found? I just want to clarify your question so that I can help you out. Also, I would recommend posting a thread with your questions so that more forum users will be able to view your questions and that you can come to solution quicker.
dK
Message 14 of 14
(2,069 Views)
