34970A termocouple configure
So, i remove de sequence structure and kept the changes, but it still re-changing for j-type, indifferent of my choice.
Icaro Kossmann
LabVIEW 8.6 Newbie.
Brazil
Message 11 of 21
(5,758 Views)
And what does the trace file show?
Message 12 of 21
(5,748 Views)
You're leaving the transducer type unconnected so it default to  "last", you should try to set it to 0 (thermocouple). In your picture the thermocouple type seemms to be set to 8: Def-T, that strange the driver i'm using the value of 8 is Def-Last (notT). That could be the reason but it's hard to tell by seeing just a part of the block diagram.
Ben64
Message 13 of 21
(5,744 Views)
So, this is my VI in LabVIEW 8.6
Icaro Kossmann
LabVIEW 8.6 Newbie.
Brazil
Message 14 of 21
(5,738 Views)
I dont know how to use trace file 😕
Icaro Kossmann
LabVIEW 8.6 Newbie.
Brazil
Message 15 of 21
(5,730 Views)
It's in MAX. Older versions were called NI-Spy. You open it and turn capture on.
Message 16 of 21
(5,723 Views)
NI Trace show me it
Icaro Kossmann
LabVIEW 8.6 Newbie.
Brazil
Message 17 of 21
(5,711 Views)
You'll have to look at the complete string for the MEAS:TEMP? command to see the scan list and the thermocouple configuration.
Message 18 of 21
(5,703 Views)
Accepted by Kossmann
From what we can see you are using the default parameters MEAS:TEMP? DEF,DEF ....
Set the transducer type input to Thermocouple and the Thermocouple type to T
see the attached screenshot for an example.
Ben64
Message 19 of 21
(5,694 Views)
I think Ben is correct. What is shown in the trace is truncated since the scan list is missing but the DEF is a problem.
Message 20 of 21
(5,690 Views)
