33522A Function / Arbitrary Waveform Generator, 30 MHz
Hi!
    I have got 33522A Function / Arbitrary Waveform Generator, 30 MHz. I want to produce two squarewave signal of 30 KHz, one on each channel. Trick is the wave form should be mirror image. I problem is, wondering if those signal is sysncronise if i drive it via LabView.
(3,159 Views)
Accepted by topic author ssnp
I have played around with one of these in the past, and these signals should be synchronized without any special commands.
This can be done on the front panel of the device or via LabVIEW. The simplest way to set these is make the channel parameters identical except for amplitude, make the amplitude of one output the negative of the other output.
One thing to be aware of ...
although synchronized, sometimes there is a slight phase difference between the two signals, you may have to adjust the phase of one of the signals to match the other. This is best done with an oscilloscope.
Cheers,
mcduff
(3,144 Views)
Thanks!
(3,084 Views)
