33220a
May I know is there already written VI to generate a double pulse from 33220A which we can control the 1st and 2nd pulse time and the time between the 2 pulses?
Thanks for your advice in advance.
(3,114 Views)
If i assume right, you are looking for a driver for an Agilent/HP 33220A right?
Have you searched the LabVIEW driver network  does this help ?
There are many types of pulses (rec, cos, sin², gauss, ..... ) but easy to create  with the signal generation vis ....
Greetings from Germany
Henrik
LV since v3.1
(3,097 Views)
Accepted by PonTM
Use generate arbitary waveform comes with its instrument driver, http://sine.ni.com/apps/utf8/niid_web_display.model_page?p_model_id=104, and write an array of data point to replect your two pulses.
(3,079 Views)
