3 digit LED display
Hello there ,
I have made a single digit display using case structure but i need to display 3 digits
can anyone help me
(4,519 Views)
For integers you can split number into digits
(4,486 Views)
Hi akshay,
some comments on your VI:
- NEVER delete the label of controls/indicators! NEVER hide the label in the block diagram!
- use a cluster to bundle the boolean indicators of your 7-LED display. Then use a cluster constant to set the indicators.
- the "Numeric" control needs a better (aka "more descriptive") label, and should be an integer type!
- use an array of those clusters mentioned before and a simple IndexArray function instead of creating a case structure with 10 cases and lots of boolean constants…
After placing those LED indicators in a cluster you can easily create an array of those clusters to allow more than one digit…
(Simple generic rule: when you need a data element more than once you should use an array of those data elements!)
(4,475 Views)
Here is a little help on your homework. Instead of using a case structure, I like the idea of a Look-up Table. Instead of having 7 seprate LED segments, combine them into a cluster. That way you can create an array of clusters to display all digits of your number. Between this and Artem.SPb's idea (edit: and GerdW's ideas), you should be able to do the rest.
Edit: a LUT of Cluster constants as GerdW mentioned would be a lot easier than what I did.
(4,470 Views)
Thank you so much for the help
but i'm getting a broken wire
(4,430 Views)
Hi akshay,
when you move that cluster into an array you also need to convert the wire to hold an array of clusters…
Didn't we mentioned that before?
(4,418 Views)
You are indexing Single Element for Display but the Indicator is array.
Change array to Element (LED Display)
(4,415 Views)
