04-29-2020 12:46 AM
Hello, I need help with LabVIEW. There is a exercise where you need to make 3 LEDs with 3 buttons. In with 1 button will light 1 and 3 LED, Second button will light 2 LED and turning off 3. (1 switch is turned on). And the third button makes all the LEDs off.
04-29-2020 12:53 AM - edited 04-29-2020 12:53 AM
Problem is not clear.
Do we have 8 different switch states and a truth table for the three LEDs in each state, or does the result depend on the order of operations as you describe. Since the switches can be operated in many other orders, you need to describe the desired output for all possibilities.
What have you tried so far? Where did you get stuck?
04-29-2020 12:56 AM
Hi Andre,
to add to Christians request: you seem to use switching buttons (in contrast to latching behaviour) so there are another 8 states you need to define!
Is the action shown in the images only valid when switching the button to TRUE? What happens when switching to FALSE?
04-29-2020 12:58 AM
Well, I stopped at the start because I am newbie in the LabVIEW. I started by connecting all the switches with LEDs but it didn't go well. So at this moment I am stuck
04-29-2020 01:03 AM
Using the NI Labview software package, write a control program using LEDs and switches. When switch 1 is switched on, LED1 and LED3 light up. When switch 2 is switched on, LED2 lights up and LED3 goes out (switch 1 is not switched off before). When switch 3 is switched on, LED1, LED2 and LED3 go out (previously switch 1 switch 2 is not off)
I've got this task. And picture attached with it
04-29-2020 01:13 AM
(Please don not use code tags for text here. It is annoying to scroll.!)
Can you show us what you tried and where you got stuck? Did you place the switches and LEDs on the front panel? Dod you place a while loop on the diagram yet?
Who gave you this task and why would he give it to you since you don't seem to know LabVIEW? Is this part of a course? How many lessons did you have so far? Did you try some of the tutorials?
(I would use an array of switches and an array of three LEDs, covert the switch array into a number and use it to index into a 2D boolean lookup table)
04-29-2020 01:36 AM - edited 04-29-2020 01:38 AM
Hi Andre,
Well, I would use an array for the LEDs, but still scalar buttons:
I use "value change" events for each button, in the image the event for button2 is shown.
I guess you can figure out the other states (button1, button3, and stop)…
04-29-2020 01:37 AM
This is where I got. 3 Switch isn't attached to anyone.
Well I am studying at the college so it is part of a course, there where about 8 lessons but they were difficult to understand because of remote study. So thanks to youtube I understood some basic knowledge.
04-29-2020 01:41 AM
Hi Andre,
You have two days left to take the self-paced courses directly at www.ni.com - they are free until end of April!
(Why do people look for tutorials at Youtube when there is a huge amount of training resources offered at the manufacturer website?)
04-29-2020 02:05 AM - edited 04-29-2020 02:09 AM
@GerdW wrote:.
Well, if the container is transparent, you would not really know the difference 😄
Yes, a 4 column LUT would be sufficient here, but I made it big enough to handle all possible combinations if that's needed in the future. 😉
At this stage or learning, I would stay away from event structure.
And NO, AndreLT, Do NOT try to copy that code. it's probably not what your teacher had in mind. Still try to understand it as a separate exercise. 😄
