2D graphics with LabView?
I am in biomedical research and am developing a system to aquire physiological and movement data from patients with movement disorders. Ideally I would like to display a picture of a ball bouncing back and forth across the screen and have the patient move a cursor to track the ball. The cursor is hooked up to a device attached to the patient. Ideally I would like to acquire a few channels of data via DAQ card while this graphical display is smoothly updating. As far as I know, LabView has no graphics capabilities like this. Any thoughts on what I should do? (Please do not suggests 3D graphics programs. Just need 2D.)
(3,394 Views)
Hi mel;
You may want to take a look at the "Bouncing Cube.vi" example. Do a search in LabVIEW's help file for the word "bouncing". This example is also at NI web site.
Regards;
Enrique
www.vartortech.com
(3,394 Views)
> Just need 2D.)
The other suggestion to use the bouncing cube is a pretty good one.
You can change the cube to a simple box or ball and
set the plot
style to fill the plot.
Another approach, arguably easier is to use the picture control
toolkit. Check out examples/picture and see if something in
there isn't a good starting point.
Greg McKaskle
(3,394 Views)
