aspoo,
If you want to use the dot as the decimal separator for all the application,
uncheck the Options/Front Panel/Use localized decimal separator". You have
to relaunch LabVIEW for this change to take effect.
If you only want to read numbers with a dot without changing the application
default, use the "Scan from String" function and with the format string
"%.;%f".
"%.;" specifies the dot as the decimal separator in the string. It is needed
only once and is applied to
all the numbers scanned.
Jean-Pierre Drolet
"aspoo"
a ecrit dans le message de news:
5065000000080000000C2D0000-1002247793000@exchange.ni.com...
> How can I interface with Visual C over the serial port. My problem is
> that I receive 12.85 in stead of 12,85. Is there
a setting to change
> in Labview so I can read doubles having dots as a seperator?
