2D-Linear Fit needed
I have to find the best straight line in a x-y measurement array.
The "Linear Fit.vi" uses a linear regression method normal to the x-Axes which leads to bad results if the sollution would be near a vertical straight line.
e.g.: with a Pair of measurement points with:
1.: x=0 Y=+1
2.: x=0 Y=-1
I would like to get a straigth vertical line (x=0, k=inf or something which represents this), the Linear Fit.vi's result is NaN
Does someone know where to find a vi for this?
Thank you for any comments.
 Greetings
Mario Hirth
(3,833 Views)
Hi Mario,
one possible workaround is to fit in both directions, i.e. y vs. x and x vs. y.
If you know your data will usually be close to vertical just do the x vs. y fit.
Hope this helps,
Daniel
(3,830 Views)
Hello Daniel,
thank you for your quick answer.
I allready had a workaround where I swap x<>y if the y elongation is bigger than the x elongation.
Leading to better results for straight lines in x OR y direction, but not in between (45deg?).
Since I use the residuum of the linear fitting to evaluate the measurement (which should represent a straight line, but I dont know in which direction), I have to be mathematically correct.
I also had a solution by iteration with: "find slope" => "turn measurement data into x-axis according to slope" => start again with finding slope => do this about 5 times etc...
in principle this works, but since I have to make a iteration with the result of this output (which is a different story), I have a iterationtask  inside an iteration task.
It works, but its neither a beatiful sollution nor a quick (means CPU-intensive).
But thank you anyhow
Mario
(3,818 Views)
Mathematically, this makes no sense to me. Can you explain what it is supposed to achieve?
What is the error in x and y for each data point?
(3,792 Views)
Hi altenbach,
Why should this make no sense?
The Linear Fit.vi trys to find a straight line which minimizes the Summ((Delta y)^2) , I want a line which minimizes Summ(Sqrt((Delta x)^2+(Delta y)^2))
In other words, not the deviation in y-direction but in a direction normal to the fitting line.
By turning the measurementpoints into the x-axis according to the slope of my fitting line, "y-direction" and "normal to the fitting line" is the same.
Shure I have to remember how much I have turned my measurement points, but this is not a real problem.
greeting Mario
(3,778 Views)
