2D Array
Hi, I would like to know how to represent the data stored in a 2D Array with values ​​between 0 and 255 (XY diagram).
Thank !!
(2,823 Views)
Your request is too vague.  You can use a table, an array indicator, an XY graph, you can replace the numbers with symbols from an extended ascii set.  Please be more specific.
aputman
(2,819 Views)
The array is already represented by a wire. I assume the datatype is U8. Are you talking about "presenting" it on the front panel?
Use an intensity graph and wire the array to it. Change the Z scale to 0-255.
(2,808 Views)
