2D, 1 column array to a 1D array?
Is there any easy way to do this? I can envision a way to do it by using loops, but that seems unnecessary. Maybe a way to transpose 2D array and convert?
(6,711 Views)
Hi GV,
what about a simple IndexArray function? (Or ReshapeArray?)
(6,710 Views)
I get index arrays and everything (I think).
Say for a 3 x 3 2D array. I know how to index to get what I want (ex. the second column only maybe). I need this single column to be transformed into a 1D array. If I transposed it, it would "look" like a 1D array, but it wouldn't be one. My problem is being able to make a 2D array that is "practically" a 1D array into a type 1D array.
Unless I'm missing something key about indexing arrays.
(6,705 Views)
Accepted by GV_KawaiiDesu
If you use Index Array one a 2D array, and you enter only ONE of row or column (not both) then you will extract that vector as a 1D array.
(6,678 Views)
As a recent example, look at my image posted here. It gets the second column as a 1D array. You would wire a zero to the lower index, leaving the row index unwired. This will get you the first column.
All this is explained in the help.
(6,669 Views)
