24 bit 2's complement hex string to number
Hi GerdW
Please see the attched 2011 vi. The example numbers are on the frnot page.
Hong
Message 11 of 15
(1,692 Views)
Hi Hong,
what's the rule to convert your 4-byte numbers to those decimal (?) numbers?
How to go from B100.0000 to "1"? And from C31F.0000 to 57d/39h? How to go from 56FE.3A00 to 26607d/67EFh?
Do you have a manual describing that conversion?
Using the logic in your VI you would need an input like F7F0.F6FE to get 14607d. How does that fit with D0C7.2000 in your example?
Message 12 of 15
(1,688 Views)
Hi GerdW
The hex number is return value from a 485 device. The dicimal number is diplay on ther software that coming wiht the device.
I do not have manul for the conversion.
Hong
Message 13 of 15
(1,680 Views)
Hi Hong,
dare to ask the vendor of that "485 device"?
Message 14 of 15
(1,675 Views)
What is this device?  Do you have a link to a manual that should describe what the data means?  Because none of  your conversions make any sense.
Message 15 of 15
(1,660 Views)
