2's comp binary Exponent/Mantissa
How do I handle a 64 bit word where the exponent is at the beginning of the Binary?
I have 4 - 16 bit words that comprise a GPS Time stamp.
The format is as follows
Binary Format: SEEEEEEEEmmmmmmm....m
S: sign
E: 8 bit exponent
m: 55 bit mantissa
Exponent signal type:
Excess 128
MSB 2^7
LSB 2^0
Resolution 1
Mantissa signal type:
Unsigned
MSB 2^-2
LSB 2^-56
Resolution 1.3878E-17
Any ideas out there?
(5,817 Views)
Hello jdam,
this looks like a IEEE 64-bit binary.
Try to read it as a DBL. I think it will turn out right the first time. If not try some of the read option (MSB/LSB difference)
Ton
My LabVIEW Ideas
(5,808 Views)
TonP wrote: Hello jdam, this looks like a IEEE 64-bit binary.
No, DBL has 11 bits in the exponent, not just 8. (SGL has an 8 bit exponent, but is only 32 bits long).
IEEE_floating-point_standard
LabVIEW Data Storage
It should not be too hard to implement this conversion using some masking, shifting and bit twiddling. Unfortunately, you loose 3 bits worth of resolution in the mantissa going to DBL, so you would need to go to EXT.
(5,799 Views)
Altenbach,
Thank you for the input and congrats on surpassing the 4k mark. Easy to see why!
Fortunately this problem comes with an example that I can use to test out my vi.
The example is as follows.
Example: The number -5.25 represented in DBL
Sign                     Exponent (8 bits)                   Mantissa (55 bits)
1                          10000011              0101000000000000000000000000000000000000000000000000000
Exp = 10000011 = 131 dec = 131-128 = 3
Mantissa = -(2^-1 (hidden) + 2^-3 + 2^-5) = - (0.5 + 0.125 + 0.03125) = -0.65625
Decimal equiv = -0.65625 x 2^3 = -5.25
Your wisdomm is always appreciated.
(5,772 Views)
Altenbach,
Can you share some our your vast wisdom concerning binary data manipulation?
I'm still working the Satellite data messages and I've come across this problem.
Three (3) unsigned 16 bit words comprise the following three variables Mo (24 bits), af0 (11 bits) and af1 (11 bits)
Word 1 - Mo (Part A)      Word 2  -  Mo (Part B), af0 (Part A)           Word 3 - af1, af0 (Part B)
(Mo) Snnnnnnnnnnnnnnn    +   (Mo)  nnnnnnnn    (af0) Snnnnnnn        (af1) Snnnnnnnnnn   (af0) nnn
(last two bits of word 3 are set to logic 0 and not used)
Mo (LSB -23, MSB -1) resolution = 1.1921E-07
af0 (LSB -20, MSB -11) resolution = 9.536743E-07
af1 (LSB -38, MSB -29) resolution 3.637979E-12
Is there a way to manipulate the bits and use scaling to solve this problem? I'm having difficulty.
What would you suggest?
(5,725 Views)
