10-09-2011 03:37 PM
Hi everyone, I have a strange problem, so I am able to use 2 scale in different (I have found the answer here in forum), but if I change the range of plot 0, the value of plot 1 is changed as well. And it's happened vice-versa. I don’t know why.
I have another problem. When I change the range, the gird is changed as well. How can I fix it?
Have you got any ideas?
LabVIEW 9.0
10-09-2011 09:20 PM
I'm not sure what the code is doing. What exactly are the knobs setting? Clearly it's not the amplitude of the signals or the scales.
Mike...
PS: in terms of the jumbled graph lines, what you are seeing is expected behavior.
