2 different Y scale.
Hi everyone, I have a strange problem, so I am able to use 2 scale in different (I have found the answer here in forum), but if I change the range of plot 0, the value of plot 1 is changed as well. And it's happened vice-versa. I don’t know why.
I have another problem. When I change the range, the gird is changed as well. How can I fix it?
Have you got any ideas?
LabVIEW 9.0
(2,382 Views)
I'm not sure what the code is doing. What exactly are the knobs setting? Clearly it's not the amplitude of the signals or the scales.
Mike...
PS: in terms of the jumbled graph lines, what you are seeing is expected behavior.
Certified LabVIEW Architect
LabVIEW Champion
(2,358 Views)
