2-Digit Seven Segment Display Counter (myRIO)
I am working on making a stopwatch that displays the time elapsed on an external seven-segment LED display. I am confused on how to control two digits of a seven-segment LED display.
I know that for the seven segments, there are the following connections to the myRIO 1900:
Segment 'a' --> B/DIO0 (pin 11)
Segment 'b' --> B/DIO1 (pin 13)
etc.
But that is for one digit. If I have two digits, how can I, for instance, turn on segment 'a' of the first digit, whilst keeping it turned off for the second digit (simultaneously)?
(2,187 Views)
Hi RavensFans,
I have a question about the 2D array that you talked about.
You said that one row will contain the digits 0-9 and then the second row will contain true or false associated with the segment of the seven-segment display. I am a bit confused about the second row of this 2D array.
If I consider the digit '8', it requires digits a, b, c, d, e, f and g to be turned on. Then in the column of '8' of the 2D array, would I wire "true" to all of the Digital Output pins of the myRIO microcontroller? ie. True to B/DIO0, DIO1, DIO2, ..., DIO6? Then, would the index array pick the columns that are required?
Thank you for your time.
(2,156 Views)
Hi Michellly,
Please read a book which explains such 7-digits display with all details. I guess books about electronics from the late 70's or early 80's do this…
You may also study the electronic schematics of an old alarm clock with such 7-digits display: here you will find hints on how to display 4 digits (and the colon in between) with less than 16 digital outputs!
Edit:
Please keep related questions in one thread. Don't spread the discussion over several threads…
(2,142 Views)
