2 COM port swithching at once!!!
 For testing purpose I made *A50$ to *A0$ so all the time I need to read 4 bytes. I tought this will make some difference but here also Its failing.  I will write and read * AA$ in same VI and will let you know.
Thanks a lot for your efforts gyus. Really greatful
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
Message 91 of 117
(1,394 Views)
What?  I thought you said you can't change the Arduino output format.  This is really confusing especially without any information about your Arduino code.
Message 92 of 117
(1,385 Views)
I am not at all changing arduino output format. This is resonse of output and I am just changing range of response I am getting from arduino. This is user defined. Somethinhg like testing sequence. Initially it was set to *A0$ to *A50$....here number of bytes are 4 and 5 so for worst case I was using 5. For crosschecking I changed upper response from *A50$ to *A0$ to make bytes to read as 4 in all the time
--Ranjeet
Message 93 of 117
(1,378 Views)
I am using a testsequence in which I am sending total 35 times including all the commnads.
I changed all the command with *AA$ and in which upperresponse as *A50$ after timeout error also 35 times it got passed. I tested total 7 times test passed.  then I changed the upperresonse to *A0$ then also it got passed.
What you suggest now?
--Ranjeet
Message 94 of 117
(1,367 Views)
To be honest, I don't really know what you just said.
So, you changed all of the commands in your test sequence to "*AA$" and it worked without errors?
Message 95 of 117
(1,362 Views)
Yes command sent was *AA$ and response range upperresponse I changed *A0$ and *50$ and in both the cases it worked fine.
--Ranjeet
Message 96 of 117
(1,360 Views)
You see one test sequences have total 35 command response. i.e. total 35 times read and write. When once it got complete all 35 without error I say test passed.
Now I changes upperresponse *A0$ and *A50$. In later case I was getting timeout error becasue worst case byte need to read was 5 and actual 4. In both the ccases it was passed
--Ranjeet
Message 97 of 117
(1,357 Views)
I'm having a hard time understanding what you are saying but do you now understand what is going wrong?
Message 98 of 117
(1,354 Views)
See I will explain now
Label Command Lower Response Upper Response
test *AA$ *A0$ *A050$
Off *S$ *SOK$
This is my test sequence. For one test when all these read write passed then I say testing it passed. Now I tested in two condition one in which upperresponse is *A50$ and other in which *A0$. In both the case it passed. I run complete above test for both the cased i.e total 7 time all above command and it got passed
I have no idea what is going wrong?
--Ranjeet
Message 99 of 117
(1,346 Views)
Well, if that one particular command works, test a different one and see if there is a specific one that is breaking things.
Message 100 of 117
(1,343 Views)
