1d array to multicolumn listbox
HEllo everyone,
 I am doing some work on array and Multicolumn Listbox, I want the hex array input should be displayed in a Multicolumn Listbox, and the total element in an array is 256, I  want the 0-15 data  from  element of an array will be displayed in first row of  Multicolumn Listbox , and on the second row 16-31 in second row of  Multicolumn Listbox and so on, how to do that?
Thank you & Best regards
syrpimp
“You must continue to gain expertise, but avoid thinking like an expert." -Denis Waitley
Message 1 of 8
(7,150 Views)
Accepted by syrpimp
Here's a way to do that.
Marco
Message 2 of 8
(7,131 Views)
exactly MarcoMauri thanks you very much... very helful and it fits my satisfaction
syrpimp
Message 3 of 8
(7,119 Views)
my problem now is how to convert them in ascii , can you help me on it, thanks
syrpimp
Message 4 of 8
(7,106 Views)
If you need to convert your U8 array to an ASCII string you can use "Byte Array To String"  vi.
Marco
Message 5 of 8
(7,100 Views)
thanks.. how about convert to ascii each value in every element of an array and display it  to multiculomn listbox, so every cell in mlticulomn listbox has its corresponding ascii code with respect to the hex listbox ?
syrpimp
Message 6 of 8
(7,092 Views)
Accepted by syrpimp
Give this a try.
Message 7 of 8
(7,072 Views)
that was great
syrpimp
Message 8 of 8
(7,060 Views)
