1D array to DBL?
I've got a 1D array composed of multiple numbers such as {1,6,5,8,3,4}.I need to convert this to a DBL, in other words make it one number :165834.
How is this done?
Message 1 of 11
(3,805 Views)
How big is the array? Is it an array of integers? An array of strings? What you show is an integer as the final value, not a DBL
Message 2 of 11
(3,794 Views)
there are 15 integers in the array.
Message 3 of 11
(3,790 Views)
Here is one example which I suggest need some modification, regarding if you have "," or not.
Even
_________________________________
Certified LabVIEW Associate Developer
Automated Test Developer
Topro AS
Norway
Message 4 of 11
(3,789 Views)
Oh, come now, you don't need any loops for this: Smiley Wink
Message 5 of 11
(3,777 Views)
that was what i was about to ask. how does it work, why is the for loop needed? so basically, we need to convert to a string, then re-convert to DBL. right?
Message 6 of 11
(3,768 Views)
Or you can go the mathematical approach.
GCentral
Message 7 of 11
(3,763 Views)
Hi crossrulz,
you don't need that exponential function:
Message 8 of 11
(3,755 Views)
@GerdW wrote:
Hi crossrulz,
Good call.  If I would have thought about it tomorrow, I'm sure I would have came to the same conclusion.
GCentral
Message 9 of 11
(3,749 Views)
Nice! I didn't know you could connect arrays directly into the number->string conversion.
Even
Topro AS
Norway
Message 10 of 11
(3,721 Views)
