1D array to Cluster of Clusters
I'm looking to turn a long array of u8 received from a 3rd party application into a cluster of status elements (cluster of clusters)
I don't like how I'm repeating the split 1d array and array to cluster conversion. Although this works for 3 elements, I wouldn't want to do it for 20. Can I set up the conversion in a more extensible way?
Message 1 of 9
(4,377 Views)
Hi JScherer,
the conversion can be made much simpler:
When you want to repeat a process step you should use a loop!
So place the conversion into a (while) loop and repeat until the remaining array is empty (or smaller then needs to be). You can also use a FOR loop when you calculate the number of conversions from array size…
Message 2 of 9
(4,364 Views)
Well, the problem is that you can't really use a loop efficiently, because clusters are fixed in size and you cannot e.g. have an array  where each element is a cluster with a different number of elements.
Maybe you want to re-think your data structures. For example you could have an output array where each element is a cluster of an array. Now each element can be of different size.
Message 3 of 9
(4,334 Views)
Accepted by JScherer
To steal from altenbach, you can do this with post-card sized code.  You just need the Byte Array To String followed by the Unflatten From String.
Message 4 of 9
(4,318 Views)
Gerd already mentioned something very similar, but it was hard to notice because he also left the original code next to it. 😉
And, no you were not stealing anything because my solution would have looked as follows:
Message 5 of 9
(4,315 Views)
Yes, by decision to allow comparison of original convoluted approach with that simple TypeCast replacement…
Message 6 of 9
(4,299 Views)
I am just not a fan of the Type Cast function.  I have been burned too many times by Little Endian formats.  So I always go for the Unflatten From String to guard against that (simply add a constant to state the Endianness instead of adding who knows how much code to swap bytes and words, etc).
Message 7 of 9
(4,292 Views)
Yes, I would probably wire the size input to a case structure and only cast if the size=9. 😄
(Also note that unflatten also has an output for the remaining string that could be checked for length.)
Message 8 of 9
(4,290 Views)
I have also used it to "chain" conversions.
Message 9 of 9
(4,244 Views)
