16进制文本转成WAV
dear labviewer,
我有一段16进制文本,如何通过labview转成WAV????
Message 1 of 15
(2,065 Views)
深 (Bit depth):32BIT
采样率:48K
Message 2 of 15
(2,063 Views)
Hexadecimal text is just a log sequence of bytes and can be anything.
A wav file is an audio file that is also a sequence of bytes, but has known structure as defined in the audio format standard.
In order to correctly parse the hexadecimal string, you need to know the structure. Do you? What was used to generate it?
Message 3 of 15
(2,015 Views)
hi brother,
I have a python script that works on converting the hex text i sent to wav, but I don’t know python. Can you help look into the code and let me know if labview can also do it? Thanks
import serial
import binascii as ba
import wave
import os
import time
from time import sleep
#from command import testcommandodelist, commandresultlist
import struct
import soundfile as sf
import numpy as np
import sys
def audio_dump_to_wav_3Mics_32bit(path,new_audio_path,wav_name):
binData = bytearray()
hexfile = open(path,encoding='utf-8')
#print(hexfile)
for textLine in hexfile.readlines():
binFile = []
#print(textLine)
textLine = textLine.upper().strip()
textline = textLine.encode('utf-8','ignore').decode('utf-8')
if (textLine[0] != ':'):continue
textLine = textLine[1:]
#print(textLine)
textLine = textLine.replace('0X', '').replace(',', '').replace(' ', '')
binBytes = ba.unhexlify(textLine)
#print(binBytes)
if binFile: binFile.write(binBytes)
binData += binBytes
endianness = sys.byteorder
crc32 = ba.crc32(binData) & 0xFFFFFFFF
numBytes = len(binData)
print('%d bytes, CRC32: 0x%08X' % (numBytes, crc32))
print(' ')
numSamples = numBytes // struct.calcsize('>f')
dataFormat = ('<%df' % numSamples) if endianness == 'little' else ('>%df' % numSamples)
audio = np.array(struct.unpack(dataFormat, binData))
audio = audio.reshape(int(len(audio)/1),1)
TOP_Data = audio[:,0]
#Top_data = audio[:,0]
#Error_data = audio[:,2]
sf.write(new_audio_path + wav_name +'.wav',TOP_Data,48000,subtype='PCM_32')
#sf.write(new_audio_path + wav_name +'_'+'32bit.wav',Top_data,48000,subtype='PCM_32')
#sf.write(new_audio_path + wav_name +'_'+'Error_32bit.wav',Error_data,16000,subtype='PCM_32')
print("audio dump to wav 黑化肥发灰 灰化肥发黑 !!!")
datapath = '/Users/h3637_h716454/Desktop/py/' # save here
fpmic = datapath + '/'
try:
os.makedirs(fpmic)
except OSError:
print('File Exists')
fp1 = fpmic + '1.txt'
wav_name='1'
audio_dump_to_wav_3Mics_32bit(fp1,fpmic,wav_name)
Message 4 of 15
(1,979 Views)
搞定没,老铁 ?
Learning from other people
Message 5 of 15
(1,959 Views)
LabVIEW is a full featured programming language and can do anything! Anything!!!
Is there a documentation for the incoming data?
Sorry, I don't use or read Python. Maybe you could use the Python node that is available in newer LabVIEW versions?
Message 6 of 15
(1,946 Views)
没呢 你也要做这个?
Message 7 of 15
(1,938 Views)
Message 8 of 15
(1,928 Views)
Yes, labview is powerful and perceptual for measurement and automation.
Python is also popular in these years, and work well in both windows and linux OS.
Thanks.
Message 9 of 15
(1,898 Views)
This is raw data, and it is mic recording data( send command to let microhone on tws earbud to record then send command to get the recording data like attachment )
Message 10 of 15
(1,819 Views)
