-1073807202 Serial Error
Error code -1073807202
A code library required by VISA could not be located or loaded.
I can't find any information about this error.  This error happend on a computer with LV Runtime installed and no development environment.  Anyone have any ideas?
Matthew Fitzsimons
Certified LabVIEW Architect
LabVIEW 6.1 ... 2013, LVOOP, GOOP, TestStand, DAQ, and Vison
(3,759 Views)
The error usually means that VISA or the VISA run-time is not installed.
(3,757 Views)
Thanks!  I will give it a try.
Matthew Fitzsimons
(3,746 Views)
I just spent a day chasing this error, uninstalling and re-installing VISA, making sure that 488.2 was installed correclty, ensuring that support for my version of LV is installed, etc.
After playing with several instrument driver examples for awhile, I noticed that all along it was a simple typo with an inappropriate error being thrown, our beloved 1073807202.
Entering a string like GPIB::14::INSTR into a VISA resource control without the quotes throws this error.  It needs the quotes:  "GPIB::14::INSTR"  , then it works fine
Odd that a typo results in an error regarding software libraries being unfound.
I don't mean this as a complaint, it was my fault, just didn't see this info out there, so send some virtual humor my way if this helps someone.
-Ben Phillips
(3,384 Views)
Using quotes is not correct with a VISA Resource Name Control. Exactly what driver are you using that you had to do this? Are you using an NI GPIB board and are you using NI-VISA?
(3,369 Views)
