1003 error at invoke node in .exe
Hello!
I Have a problem at an invoke node when running an .exe and I have no idea what the problem is. There's no problem in the development system.
Here's a picture of the code..
Thanks in advance
Message 1 of 9
(4,537 Views)
Both of your figures appear to be the same. You didn't indicate which node is actually generating the error, so I'm going to guess on this: Error 1003 When Using VI Server in a LabVIEW Application.
Message 2 of 9
(4,498 Views)
I don't actually know which node is causing the error, but I know it's some of the invoke nodes. Sorry I accidentally put the same attachment twice.
Our software has a lot of dynamic vi calls. I had some problems calling the vi:s in .exe but they should work fine now. I just added a strip path at the main vi.
Thanks for the link but I doubt it's the solution to my problem. I have LabVIEW 8.5.1
Message 3 of 9
(4,485 Views)
To find out where the error originates, place a probe on the error cluster wire and monitor the point where the error first appears, it will be the object in front of the probe.
R
Message 4 of 9
(4,478 Views)
You could post your code for people to have a look at it.
R
Message 5 of 9
(4,474 Views)
Problem solved! I just needed to add a few vi:s in the "always included" section when making the exe.
Thanks for the help anyway.
Message 6 of 9
(4,468 Views)
So just to set the record straight Saverio was correct when he pointed at the KB article to include all requred VIs.
Ben
Message 7 of 9
(4,460 Views)
Yes you're right. Sorry guys.Smiley Happy
Ben
Ben
Message 8 of 9
(4,456 Views)
Now if I could only guess as well when picking stocks. Smiley Very Happy
Message 9 of 9
(4,438 Views)
