 knoerifast
			knoerifast
			11-17-2017 07:48 AM
Hi All,
As far as I know, the LabVIEW 2017 Module for LEGO® MINDSTORMS is not available yet.
I was wondering if the LabVIEW 2016 Module for LEGO® MINDSTORMS works under LabVIEW 2017.
Thanks for responding.
11-20-2017 08:51 AM
Hi knoerifast,
As you mention the LabVIEW 2016 Module for LEGO® MINDSTORMS is the latest release and there are no current plans for a LabVIEW 2017 Module for LEGO® MINDSTORMS.
There is unfortunately no way to use the LabVIEW Module for LEGO MINDSTORMS 2016 with LabVIEW 2017 so our recommendation would be to downgrade to LabVIEW 2016.
I'm sorry this is unlikely to be the reply you were after - but I hope this helps answer your questions.
Kind regards,
Rebecca
 mk@FHI
			mk@FHI
			02-17-2018 05:21 PM
I have to give a Course and my device is Lego Mindstorm, now the complete Computercluster is installed in Labview 2017 and I can not teach.
Is there a possibility to install the labview 2016 module on labview 2017. If not I have a large Problem! What will be in Future? Is NI not supporting Lego Mindstorm any more?
Best Marcel
 LPS_JSanchez
			LPS_JSanchez
			02-23-2018 04:02 AM
Same here !
We can't downgrade our computer park.
Is it possible to have a beta version on the 2017 module ?
02-26-2018 02:08 AM
 DODonovan
			DODonovan
			04-24-2018 10:36 AM
I would also like to add my concerns to those of the other contributors. I use the LEGO module, among others, for lecturing and my engineering department has just postponed upgrading to LV 2017 as a direct consequence of this issue.
Thank you to the other contributors for highlighting this issue, as it has saved my support staff here a lot of effort...
I too would like to know if there will be future versions of the LEGO module as this will have large implications for the course in question and the materials I resource it with...
Donal O'Donovan
 MK_Berlin
			MK_Berlin
			11-06-2018 11:04 AM
Dear All,
is the a plan for developing LabVIEW 2016 Module for LEGO® MINDSTORMS futher?
What is the problem to convert the drivers and VIs?
Best
Hepman
