‎02-11-2011 12:11 PM
The help for Format Specifier Syntax doesn't say anything about special characters (tab, eol, etc)
Since the usual LV "codes display" mode does not seem to exist in LVWUIB, it's a game of trial and error to obtain the proper string.
Luckily you can create a string with a CR by simply pressing "Enter" while typing in a string constant. This does not work with TAB though...
Luckily too, it appears that when scanning a string for numbers, spaces, tabs etc are simply ignored.
However, I want to generate a TAB formatted string so that I can copy and paste it into another program and process it from there.
How can I do this?
X.
‎02-14-2011 11:22 AM
Hi X-),
I tried to use a "\t" but it never worked. I'll have to play with the string formatting to see if this is possible. Thanks for bringing this to our attention!
‎02-14-2011 12:06 PM
If I may suggest an improvement for the help (pretty concise at time: "check the Silverlight manual" or something of that kind): provide the same list of examples as provided for string syntax in LabVIEW.
‎02-15-2011 09:45 AM
Hi X-),
I've also double-checked the MSDN documents to make sure I've tried everything and am unable to get it to work. It's almost like the \ code doesn't work. I'll double-check the correct use of the custom format code.
You can always provide feedback directly to R&D by clicking the Send Feedback button in the upper-right corner of the Web UI Builder editor.
