LabVIEW Web UI Builder and Data Dashboard
How can i make hyperlink to local file for dowloading
Has anybody gotten this VI to work? I have tried under latest version of IE and Firefox.
It copies the file but I never get the prompt to Save the file ... The Content-Disposition from HTTP forums say this should work.
I have code snippet in HTML file I wrote that verifies the browser prompts for file to save.
Message 11 of 28
(6,730 Views)
Hi RGSchmidt,
I just tested the VI in Chrome and IE and it seemed to work fine.
Is your browser setup to save to a default location?  My Chrome is so the file was simply downloaded to my default downloads directory, without a prompt.  Is this what you are seeing?
Have a great day,
Chris V
Applications Engineer
Message 12 of 28
(6,722 Views)
Hi Chris,
I never see the prompt or the file downloaded in IE or Firefox.
Randy
Message 13 of 28
(6,718 Views)
If you load the web service URL directly in your web browser (not in UI Builder with the hyperlink control), do you get the download prompt then?
I wonder if it could be a popup blocking issue or something like that.
Message 14 of 28
(6,714 Views)
Great idea ... It worked by directly loading the URL that is passed into the GET function in the vix file called from the Web UI in both Firefox and IE
Where could the issue be, I am very confused
Message 15 of 28
(6,710 Views)
I tried it in Firefox in UI Builder and got the download prompt too. I have Block pop-windows on in Firefox but I still had no issues.
In your hyperlink control's properties, is TargetName still "_blank"?
Message 16 of 28
(6,704 Views)
Not sure where to find the hyperlink control properties ....
Message 17 of 28
(6,699 Views)
In the Properties window on the right side of your screen, you should find TargetName in the Behavior section.
If you don't see it there, you can hit the sideways Properties button, or bring it back if closed from View ribbon tab > View Panes > Properties.
It sounds like you haven't changed TargetName though, so that probably isn't the problem. Can't think of other issues that would cause this though.
Message 18 of 28
(6,696 Views)
Do not see TargetName in the Properties window ... but I changed little if anything for the properties.
Message 19 of 28
(6,692 Views)
I'm attaching an editor screenshot for configuring the hyperlink - can you confirm that your control has all of the red boxed properties set up correctly? Another possibility is that you put the URL in the "Content" (link text) rather than the Target URL, then nothing would happen when you clicked it.
Message 20 of 28
(6,688 Views)
