LabVIEW Web UI Builder and Data Dashboard
Data Dashboard - Indicators and Controls
Hi, anyone have or know where i can find documents or books about data dashboard, because i wanna know which type of shared variables are necesary for each control or indicator in data dashboard, for example i wanna know about Drop Down, which kind of shared variables does it needs to function, right now i just saw how to write the values i want to see in my drop down but there's 2 options when im trying to connect the shared variable, should i use Selected Item Index or Items Strings, i want to select the value for the case structure( see image)
(8,872 Views)
You can see the data types in the in app help.
http://digital.ni.com/public.nsf/allkb/D9B247551BE7F46A8625795000552CDE
Cheers,
Brandon
(8,860 Views)
Cheers,
Brandon
Thank you for the support, but it doesn't show me how to use the control im looking for (Drop Down)
(8,833 Views)
For the Dropdown control, you can use an Int32 shared variable. In Data Dashboard, you'd pick the "Selected [Item] Index" property, and connect that to your shared variable. Then, with the control selected, click the gear icon in the top right corner, and pick "Strings" to configure the item names for the dropdown.
(Note: You can send the item names from LabVIEW too, with an array of strings bound to the Item Strings property in Data Dashboard. But if you have just a couple of items, it's often easiest just to type them in from Data Dashboard.)
(8,814 Views)
