LabVIEW Web UI Builder and Data Dashboard
Current Date in WebUI
I recently had to get the current date (could be quite easily expanded to time also I believe) and found a solution I thought I would post incase someone has this problem.
It means you don't have to use a webservice like this tutorial suggests: http://zone.ni.com/reference/en-XX/help/373286A-01/uibuilder/wuib_gsg1/
The trick is using pythons datetime class.  I find a lot of cool basic functions can be used this way.  Here is the code that is run when the stop button is pressed:
from datetime import date
runtime.SetProperty("Output.Text",str(date.today()))
(6,861 Views)
Hi jdaming,
Very cool!
You might consider posting this in the NI Community as Example Code.
Have a great day,
Chris V
Applications Engineer
(6,854 Views)
