LabVIEW Shortcut Menu Plug-Ins
Alphabetize Event Structure.llb (sort event structure frames alphabetically)
Overview
Takes an event structure and rearrange the frames so that they appear in alphabetic order
Description
After discovering that the existing sort function doesn't work, I made a shortcut menu plug-in to rearrange the frames on an event structure so the appear in alphabetic order
Hardware and Software Requirements
LabVIEW 2015
1.Copy the llb to one of the seach paths described in the shortcut plug-in documentation
Comments
Chris_Cox
on
using LV2016,  I see the option in the short cut menu, but can't seem to get it to apply to any event structures.
anyone have success with this?
nanocyte
on
I was seeing similar issues. I have the "separate compiled code" flag checked in that VI. I'm wondering if there's a LabVIEW bug where it doesn't realize it needs to recompile for the newer version.
Some things that might help:
  • Uncheck the separate flag on the VIs and controls in the llb
  • Try a mass recompile on the llb folder
  • Clear object cache
I think the plugins are loaded when you launch the development environment so you'll have to close out and reopen LabVIEW
AristosQueue (NI)
NI Employee (retired)
on
There's a helper VI to avoid having to quit and restart. After you make an edit, open and run
resource\plugins\PopupMenus\support\Refresh Menus.vi
Chris_Cox
on
Thanks, AristosQueue! This totally worked.
Thanks so much nanocyte.
