LabVIEW Public Beta Program in 2023
Bug Format Into String Display Style Issue
I believe this bug exists in other versions of LabVIEW, but still it is a bug and I thought I'd mention it while this beta is open.
If you drop a format into string function, then wire a string constant to the Format String, which uses a \ style, then the values in it won't be preserved, if you use the Edit String Format window.  Here is an example:
Here I have two inputs for a numeric and string, with a tab between them.  If I right click the format into string and go to Edit Format String, and then check Use Minimum field width of 0 on the numeric, I end up with this:
Here it added an additional \ which is an escape character meaning I no longer have a tab between the inputs.  The Edit Format String dialog should not add this additional character.
(1,787 Views)
I'm not sure this is actually a bug.  Your two strings result in the same output.
(1,759 Views)
I'm very confused, but you are right.  This must be some weird thing with the format into string function behaving differently then I expected.  If the normal display shows "\t" I expect it to display a "\t" not a tab.
(1,754 Views)
Nope. The Format into String function had this since a long time. I considered it more a feature than a bug, trying to work for people even if they do not know about backslash code display modes.
Yes it is kind of inconsistent but I have not yet come across a case where I would have needed the literal backslash here.
Rolf Kalbermatter  My Blog
(1,678 Views)
