LabVIEW Project Providers
Enable/disable menu item
I would like to ask, how can I selectively enable/disable custom menu items. For example, I added "Tools/example item 1"  and "Tools/example item 2" to LabVIEW tools menu and I want, based on certain conditions disable/enable these items - based on where they are called from (whether from init screen, from  VI or from project). I also want to conditionally disable "example item 2", so that it will disabled until "example item 1" is called and executed. I know this is possible since several LabVIEW toolkits use this. Can someone please advise me on how this is done?
Message 1 of 8
(8,917 Views)
Are you referring to the right-click menu item? If so, that's pretty straight forward. Typically I would do that in the OnPopupMenu.vi method. Here's an example of that:
The source code for this provider is available on my GitHub: https://github.com/TomsLabVIEWExtensions/Toggle-Debugging
Hope this helps 🙂
Message 2 of 8
(8,909 Views)
Sorry, I re-read your message and you specifically asked about the LV Tools menu.
I haven't been able to find a way to do that (yet) as typically you initialize your tools menu in the init.vi method (which is only run once).
I will edit this reply if I come across anything.
Message 3 of 8
(8,908 Views)
Thank you for your reply McQuillan,
yes, I am looking for the disabling of tools menu items. What I want to do looks like this example from Tools/Advanced menu with items "Export Strings..." and "Import Strings...":
Message 4 of 8
(8,906 Views)
Hi Rashek,
I don't think this is possible.
Unfortunately  "Export Strings..." and "Import Strings..." is not implemented as a provider.
Message 5 of 8
(8,902 Views)
Yeah, I would tend to agree with Hypiz. I'm normally pretty good at finding the source code for the native LV plugins to use as examples - I was able to find Mass Compile. But I couldn't find Export Strings anywhere in program files (I did a global "everything" search on my PC, then manually looked in the <labview>\project directory and the providers directory).
Message 6 of 8
(8,898 Views)
It should be possible, for example this Add-on has it.
Message 7 of 8
(8,892 Views)
Wow, you're right.
The magic is hidden in GlobalItemInterfaceVI / Global_OnUpdateCommand.vi which is called item by item and where you can modify each of them.
Is it enough like this or shell I be more specific?
Message 8 of 8
(8,878 Views)
