Online shopping is currently unavailable.
Please contact us for help or try again later.
08-17-2009 01:55 PM
I have just re-installed LabVIEW 8.5 (prof. dev. sys) on another winxp desktop, the MathScript node has disappeared from the structures palette and I'm unable to resize or modify the existing nodes in my code. The mathscript examples work but are not editable.
Ideas?
Solved! Go to Solution.
08-20-2009 02:59 PM
10-02-2009 02:50 PM
GrantM wrote:
It sounds like you did not successfully activate LabVIEW on that computer. This behavior is expected when the MathScript license is not activated. To be sure, you can verify if the "MathScript Window" item has also disappeared from the Tools menu.
To check your licenses and activate if necessary, launch the NI License Manager from Programs >> National Instruments. Under the LabVIEW 8.5 section, verify that "Professional Development System with MathScript" is activated. If not, you will want to activate this license to use MathScript.
Grant M.
Staff Software Engineer | LabVIEW MathScript | National Instruments
