LabVIEW MathScript RT Module
error 1047 LabVIEW: LabVIEW failed to send variable to the script server. Server:""
I have been some running MATLAB scripts in LabVIEW for two years and this past week I am getting a new error.
The script works in MATLAB and the MATLAB command window that opens as the MATLAB script node runs. It just does not work when running the VI that contains the MATLAB script node. I have made it work by loading in the variable that is the output of one of my MATLAB functions and commenting out the MATLAB function, then commenting out the load command and uncommenting the my MATLAB function again. I also have seen where it will sometimes work on the first try then not work after that.
Your help is greatly appreciated.
-JEprime
(10,202 Views)
Hello JEprime,
The following documents may be helpful:
KnowledgeBase 2VNDL65Z: Why Do I Get Error 1047 When Trying to Use The MATLAB® Script Node in LabVIEW?
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019Lk2SAE&l=en-US
KnowledgeBase 3YL9KFHV: Calling a VI with a MATLAB script node by reference
http://digital.ni.com/public.nsf/allkb/12996CAE3150E4318625719500562672?OpenDocument
Due to the behavior you are describing (the call works the first time), I would suspect that the second link (3YL9KFHV) is more relevant.  If the steps outlined in that KnowledgeBase do not resolve the problem, please let me know, and include any and all information that you believe is relevant to the issue in your post, including the software versions being used and what sort of operation you are attempting to perform when you see this error.  Any information on how this particular script differs from the applications you have built successfully in the past would also be helpful.
Tom L.
(10,184 Views)
