LabVIEW MathScript RT Module
crash due to matlab function
Hi All,
My LabVIEW VI crash (Exception: Access violation (0xC0000005) at EIP=0x00000000) when it runs to a matlab function "inv". Seems it is a normal matrix function and should be supported in mathscript. After I delete this function, everything works fine. Can someone give me any clue on how to fix this? The crash report is as following.
Jiaqi
Message 1 of 8
(9,623 Views)
PS: The LabVIEW I'm using is 2013 SP1 and the MATLAB is R2013b.
Message 2 of 8
(9,621 Views)
Are you using the Mathscript Node or the MATLAB® Script Node? Also, what is the size of the Matrix you are dealing with? Are you dealing with 32-bit or 64-bit LabVIEW?
MATLAB® is a registered trademark of The MathWorks, Inc.
Miles G.
Emerson Test & Measurement Group
Senior System Support Engineer
Message 3 of 8
(9,595 Views)
The error message says 32bit. Seems the VI is loaded over the network.
Is your matlab 32 or 64bit?
Message 4 of 8
(9,587 Views)
Hi Miles,
I use Mathscript Node and the Matrix size is 3*3. LabVIEW is 32-bit. The funny thing is it worked fine yesterday afternoon and crashes again today with nothing changed:(.
Cheers,
Jiaqi
Message 5 of 8
(9,576 Views)
Hi Altenbach,
You are right! The VI is loaded over the shared drive. Would this be the reason?
Cheers,
Jiaqi
Message 6 of 8
(9,574 Views)
Have you tried to simply restart the computer and try again? Do you run any unusual antivirus software?
Message 7 of 8
(9,570 Views)
I tried to restart the computer but it didn't work. The antivirus software was installed by the uni IT so should be OK.
Message 8 of 8
(9,566 Views)
