LabVIEW MathScript RT Module
Matlab's Eval and num2str commands
Accepted by corbin.wilhelmi
Cell arrays were added to MathScript in LabVIEW 2012. The "cell" function itself is not implemented, but you can just assign values  to create cell arrays:
new_cell_array{1} = [1 2; 3 4];
new_cell_array{2} = [7 8 9];
This will perform much faster than using the "eval" function. That being said, if you can write your code only using regular arrays, it would perform even faster than using cell arrays.
Kevin C.
Message 11 of 12
(3,856 Views)
Thanks Kevin, that is what I am trying to do now.
Thanks to everyone else for your help, it is greatly appreciated.
Message 12 of 12
(3,852 Views)
