LabVIEW MathScript RT Module
Showing results forĀ
Search instead forĀ
Did you mean:Ā
Matlab file in MatlabScript or MathScript
Heloo
I need help in for loop which i impliment in Matlab
for i=1:16:256  %% where 16  is my jump and 256 is my total iterations
i=out; % out  is some variable
end
when i write this Script in MathScript or MatlabScript and try to get the output of  variable "out" it  gives me only the last value which is 244(last value).I  have changed the data type to "DBL". Also tryed to read "out" as array but only last value is comming. while i am interested in values like 1,17,33,49,65. . . How will i get these values as output in one by one iteration.ALso For loop of Labview 8.5 which i am using give the last value.
Regards
Madd
(7,886 Views)
Hi Madd
When using the Mathscript node, you need to be exact with the datatype you output. In your case, you need to right-click on
the output node and Choose Data Type > 1-d array> I32
as you want to output an one dimensional array of integers. You don't need to do the same for the inputs, LabVIEW figures the datatype automatically
as it is usually a direct wire from a control and not a result of compiled text code.
KostasB
NI UK
Message Edited by KostasB on 02-13-2008 03:26 AM
(7,880 Views)
TNX
 WORKS FOR ME
(7,851 Views)
Hi
i think your m code is wrong ,check once and try
use this one
t=1;
out(t)=i;% out  is some variable
t=t+1;% out=out+1
end
or
sree(1:256/16)=1:16:256
i am not expert in this just i am telling.
all the best
Sreenivasulu.O
(7,688 Views)
