Online shopping is currently unavailable.
Please contact us for help or try again later.
04-20-2009 03:28 AM
Hi!
I am trying to use a Mathscript node in LV 8.5.1, but with no success. I get the
error "VI Failed to compile" and the Mathscript is "marked as the main error". I have
used Mathscripts before but never had these problems. I use Windows XP SP3.
Everything works fine when I try the Labview Mathscript Example.
Do you have any solution for this problem?
Thanks in advance!
/Mattias
04-20-2009 09:24 AM
04-20-2009 09:55 AM
I never got everything back and right again, so I finally removed and reinstalled Labview. I changed the data.ctl to another name, now everything works fine. I will make sure to use "unique" names in the future :-).
Thank you for your time.
/Mattias
07-24-2009 05:39 AM
It looks like I might be having the same sort of problem in 8.6.
I have a large project (deadline in several hours, of course) and suddenly one of my VIs will not compile.
Can anyone tell me if there is something in this VI that is causing the Mathscript node to fail?
I don't really have time to reinstall!
07-24-2009 10:37 AM
07-24-2009 12:12 PM
Thank you! It was late, and the couple things I tried didn't work!
Any ide if these things will be fixed in LV09?
