LabVIEW MathScript RT Module
MathScript does not appear in Structure
Hello! A question! i have installed the MathScript RT Modulo 2015 from the page of NI, but this is not in my palette of structure. I have to do something more? i can see in my License Manager NI the MathScript with a yellow color and by next i can read 44 days of evaluation. If i check i can see other option about MathScrip that says: ''Activate'' but for this i need a code... i don't understand why i need a code for activation if this is for evaluation!! Can you help me please? Thanks a lot! 🙂
(5,513 Views)
Accepted by topic author nathaliemay2
Hello Nathalie,
Did you restart your computer after installing the MathScript RT module?
Also, this customer had a very similar question as yours: https://forums.ni.com/t5/LabVIEW-MathScript-RT-Module/mathscript-not-available/td-p/966294
What happens if you try using the "MathScript Window"?
Anyela
(5,459 Views)
