LabVIEW MathScript RT Module
LabVIEW MathScript does not support the syms command
hello,
i am trying to making system which require symbolic matrix, i tried it in matlab by using syms command , i get symbolic matrix in matlab. but i wanted to do it in labview because my other system in labview, so please help me out...
sample of matlab code:
syms G11 G12 G22
A=[G11 G12; 0 G22]
 Itry in matlab it work fine.. help mi with labview
(6,506 Views)
Hi
Were you able to find a solution to your problem? I tried using the same command (syms) and it doesn't work.
(5,697 Views)
Try to Use " global " instead of " syms "
(5,585 Views)
