LabVIEW MathScript RT Module
How i do i activate the Mathscript RT module in LabVIEW 2010 student ed for OS X?
Hi ScottH,
We are still working on debugging this issue. Thus far we have been unable to reproduce any results which makes debugging very difficult. Would you be willing to post a screenshot of your About LabVIEW page?
K Scott
Message 21 of 32
(5,518 Views)
All,
After further investigation we have come to the following determination: For one reason or another your LabVIEW may not have installed the license file correctly. This is not an issue with MathScript as MathScript is expected not to work with a base edition of LabVIEW. I would recommend that you reinstall your LabVIEW installation and make sure to specifically select the license to be installed. You can do this by running the installer and pressing the "Customize" button. You would then select only the license file to be installed. If you have further questions regarding that please ask and I will do my best to help.
K Scott
Message 22 of 32
(5,498 Views)
There is no clear option to just install just the license file.
Doing a everything-checked customize install on top of my current install seems to make mathscript work, but FFT is not supported. The signal processing menu is also empty. I just want to do a FFT of a signal with or without mathscript.
I'm including screenshots of the installer customize options (which one is license file?) and the splash screen.
-Scott
@K Scott wrote:
All,
K Scott
Message 23 of 32
(5,489 Views)
Also, is it normal for LabVIEW on the Mac to ask you to enter your root password all the time so it can "make changes?"
Is there a permissions problem?
-Scott
Message 24 of 32
(5,488 Views)
I posted the splash screen which is the same as the about screen (I think).
@K Scott wrote:
Hi ScottH,
K Scott
Message 25 of 32
(5,487 Views)
Nope, I was wrong. Mathscript is still busted. I dropped a formula node in by mistake (tired) when I was testing to see if things were fixed.
I'm including a screenshot of the error I get.
-Scott
-Scott
@K Scott wrote:
All,
K Scott
Message 26 of 32
(5,484 Views)
It would seem your installer is definitely corrupted and/or missing components. The custom install dialog should look similar to my attachment. Give me a little time and I will send a pm to discuss further options.
Cheers!
K Scott
Message 27 of 32
(5,454 Views)
A-OK. Your installer looks much happier than mine. Perhaps this is an issue with the Sparkfun+Arduino bundle? Or was that intended to be a full student version?
-Scott
Message 28 of 32
(5,443 Views)
-Scott
From what I understand it should be a full student version. I have sent you a pm with further instructions. Please review them when you get a chance.
K Scott
Message 29 of 32
(5,433 Views)
This is really upsetting!  I bought the $70 version of the student edition for mac so I could work on school assignments and Mathcript isn't even supported?
Guess I'll be spending my time in school labs.  Any chance of a refund?
Message 30 of 32
(5,247 Views)
