LabVIEW MathScript RT Module
Create executable by mathscript or from Windows command window
I have a lot of VIs that needs to be built into executables. So I am thinking to write a script to save some time.
MathScript windows looks a lot like command window in MATLAB so I am just wondering if there is a way to create executables by using mathscript?
Or is there a way to build from windows command window?
Thanks for your reply and have a nice day.
Yan
(7,989 Views)
MathScript is not used to create executables. You need the application builder.
(Your question is not very clear. Are you possibly trying to build executables that contain mathscript code. Please clarify)
(7,986 Views)
Sorry for the misleading subject.
(7,982 Views)
Accepted by topic author will2km
You can use the tools in the Application builder palette to write a LabVIEW program to automate the building of applications.
(Somehow I don't quite get what you want. Building is typically trivial compared to writing the program or configuring the build.)
(7,979 Views)
Thanks, that's what I am looking for.
I just have a LOT of VIs, and I need to build them on an everyday basis...
Smiley Happy
(7,975 Views)
