Online shopping is currently unavailable.
Please contact us for help or try again later.
11-01-2013 12:35 PM - edited 11-01-2013 12:38 PM
I have a lot of VIs that needs to be built into executables. So I am thinking to write a script to save some time.
MathScript windows looks a lot like command window in MATLAB so I am just wondering if there is a way to create executables by using mathscript?
Or is there a way to build from windows command window?
Thanks for your reply and have a nice day.
Yan
11-01-2013 12:40 PM
MathScript is not used to create executables. You need the application builder.
(Your question is not very clear. Are you possibly trying to build executables that contain mathscript code. Please clarify)
11-01-2013 12:44 PM
11-01-2013
01:07 PM
- last edited on
05-07-2026
04:48 PM
by
Content Cleaner
You can use the tools in the Application builder palette to write a LabVIEW program to automate the building of applications.
(Somehow I don't quite get what you want. Building is typically trivial compared to writing the program or configuring the build.)
11-01-2013 01:11 PM
Thanks, that's what I am looking for.
I just have a LOT of VIs, and I need to build them on an everyday basis...
